Old 03-02-2009, 17:17
Default Rear subframe camber correction
A while ago I bought a spare from Silviagod which I had a local fabricator weld on some brackets to the outters mounts which I slotted. I then gave it to a local company (Vulcan coatings in Basildon) whom bead blasted it. They then primed and coated it with satin black. I cant believe how good it came out as it looks like new and only cost me £30
Old 03-02-2009, 23:59
paulsilv's Avatar
paulsilv paulsilv is offline
Very nice.
Where are the bushes from and are they Poly ones
Old 04-02-2009, 10:37
I got them from MJP for about £60. Looking at their website it appears to be down atm
http://www.mjpauto.com/
Old 23-04-2009, 20:30
Whilst waiting for the machinists to do the head work on my Auto, I spent most of the day today dropping my old subframe. Over the last six months or so I have notice a knocking noise from the rear getting worse. Recently the backend has been feeling very twitchy and now I know why. One side of the subframe bush was not held in at all !
Old 23-04-2009, 20:31
So out with the old ......
Old 23-04-2009, 20:33
and in with the new......
Old 23-04-2009, 20:34
just got the trailing arms, ARB and brakes the finish tomorrow for the Mot which is due
Old 23-04-2009, 21:27
They look like MJP's Z31 bushes ?
Link
Old 25-04-2009, 16:31
Yep that they are !
Link
Old 25-04-2009, 16:32
I cracked on today with refitting the trailing arms etc.
I bought some new inner bolts a while back so the camber can now be adjusted on the outter mounts. One thing I should have checked however was that they are the same diameter as the outter bolts ie were they fit in the trailing arms.
It was only when I offered them up I found out that the inner bolts dont go in the outter trailing arm bushes. The inner bolts have a diameter of 14mm --- The Outter bolts have a diameter of 13.4mm. After scratching my head for a while, I decided to use the none adjustable originals on the outter points for now and get the others milled down to size.
