Old 09-11-2009, 11:38
Default Det s13 block with et s12 head cambelt,head gasket and head bolt info
The below code is for a Q&H belt. Its for if you want to fit aN et head to a det block. The bottom crank sprocket on the det block will not except a 8v belt as the gapping in the teeth is slightly smaller .The new belt has slight movement on the upper sprocket when meshed from the different gapping but it is safe due to the larger surface contact and diameter of the sprocket.
Q&H
QTB 200 95X3/4"
Old 09-11-2009, 11:44
A DET headgasket fits with no mods.
DET head bolts all fit with DET headbolt washers.
You will need a longer head bolt on the bolt near the dizzy. about 1 " longer.take a det headbolt to a fixings shop for this
2 head bolt washers on the headbolt next to it on the inlet side
Old 09-11-2009, 11:50
why bother tho ?
Old 09-11-2009, 14:49
seem to recall a primera headbolt can be used for the longer one.
Good wirte up btw Pukka
as for the point, it gets you stronger rods and pistons relativelt cheaply and doesnt have any wirning/ecu issues to worry about compared to a complete engine swap
Old 09-11-2009, 17:09
yup and piston cooling oil squirt jets
Old 09-11-2009, 17:51
gripo's Avatar
gripo gripo is offline
I wonder whos car you are working on then Pukka?
