Old 16-12-2009, 23:09
Default New S12 Owner
Just saying hello.
Bought my s12 a couple of weeks back.
1987, White, 35k.
All standars apart from a 2.5" straight through exhaust.
Bin working on the underside of the car in my spare time cleaning it up ready for when i get it on the road next year.
Just bough a water pump, temp sensor, thermostat and timing belt from Mike Feeney at MJP
Does anyone else have difficulty with the plug leads? Took the plugs out after a little struggle just to check how shes running and then spent an hour trying to get number 3 back in. Now either im doin sumin wrong or its the flimsy leads?
Old 17-12-2009, 13:31
old-and-rusty's Avatar
Welcome .
Just make sure that the metal contact inside the plug lead hasn't closed up or become miss-shapen.
Regards,
Ian.
Old 17-12-2009, 18:18
Do you remove anything before changing them?
Its quiet a squeeze
Old 17-12-2009, 20:40
t'was a bit of a pain the ass when I did mine a little while ago. Make sure there's none of the old plug contact stuck in the lead.
Old 18-12-2009, 15:22
Tbh. The easiest way to do it is use an old spark plug and try it for size out of the engine. That way you can judge if the plug contact is okay .
Regards,
Ian.
Old 18-12-2009, 19:39
Yea that swhat i ended up doing.
My hands are all mangled now lol
Old 21-12-2009, 09:47
If ur going to be doing a lot of work on the s12, you'd better get a big box of plasters....lol..... .
Regards.
Ian.
Old 21-12-2009, 15:54
Yea ill remember that.
Got plans for an intercooler, the S13 front coilover conversion and some ssr rims for the summer.
Knowing me that may change though
Ill get a Project thread up later on sometime
Old 22-12-2009, 08:30
Welcome seems that tho you have a good low mileage motor. Good luck with the project. Please update your location when you get a mo
