Old 04-04-2010, 23:10
Magical Trevor's Avatar
Default Need some help with wheels and tyres
Howdy if youve read my previous posts ive been looking for a set of wheels for my silvia i know its a 4 x 114 pcd and et is how far it sits in or pokes out..? but whats the maximum i could use?
ive found the wheels but the fitting is 4 x 114 et 10 16 x 8
Will these clear the arches on a car running no spacers and lowered no more 40 mm? what would be the size of tyre to buy to fit these? profile wise?
Thanks
M.T
Old 06-04-2010, 08:23
Might be a touch sticky-outy (so to speak heh) and will probably catch the arches on the rear. They also on the big side tbh. I would think smething like a 205/5516 will be somewhat stretched but do-able, a 225 would sit better but you'd need a very low profile. Something like 225/40 16 - not so cheap, more than most 17s. Only way to know is try it.
For the record 205/50 16 on a 7' rim is perfect for an S12.
Old 06-04-2010, 13:23
gripo's Avatar
gripo gripo is offline
I have 215 45 17 on mine with the suspension lowered with no clearance issues and no spacers needed.
Old 06-04-2010, 19:44
they will be out of the arch and illegal with that offset
Old 07-04-2010, 00:14
irish s12's Avatar
Depends on how much power and torque you are trying to put down to be fair.
Old 07-04-2010, 09:33
I meant in the context of 16s and factroy rolling radius
