Old 26-07-2010, 20:00
Default engine smoke-turbo i think
another prob is i'm getting a little smoke from the motor a grey blue colour
symptems
when generally drving around town & hard accelleration its fine with no smoke
it just smokes a bit when i come to a set of traffic lights or on tickover when warm
my suspisiton is the oil seals in the turbo are going/gone
i've compression checked the motor & alls good, rolling roaded it & all fine
just tickover smoke?
Old 26-07-2010, 21:49
irish s12's Avatar
Deffo the turbo I'm afraid
Old 27-07-2010, 10:24
one else thing the same as me & irish s12
to be honest i dont mind if its the turbo as i'd upgrade to a t25/t28
anyone got any turbo recomendations?
i still have a saab/volvo intercooler i need to put on so if i complement it with a nice turbo to match
Old 27-07-2010, 10:36
if its happening when you lift off it could be turbo or valve stem seals. They are the cheapest to replace whilst the head is on, if its an ET that is. Is there any play in the turbo ?
Old 27-07-2010, 17:13
it dont smoke when i lift of the throttle you can gun the car up or down the gears with no smoke!
it smokes just on tickover or on starup when its been run, my MOT man ha let me go on it for 2 years on the smoke test
my emisions are fine though! lol
i presume cause it only smokes on tickover or startup when the car is warm its just oil from the turbo getting burnt in the exhaust
lewt me know ya thoughts
Old 27-07-2010, 17:56
would this fit or is space a bit of a squeeze
http://cgi.ebay.co.uk/GT3076-Turboch...item1e5adbe2fc
Old 30-07-2010, 18:38
irish s12's Avatar
No it wont fit,and it will last about a week.Don't buy anything that isn't a genuine garrett t25 or t28
Old 30-07-2010, 21:00
cheerz irish! i'll be on the lookout for either of those then,
any probloms fitting a t28
Old 30-07-2010, 21:23
irish s12's Avatar
The t25 and the t28 aren't direct fit,you will need to modify your intercooler pipes and the t28 needs an adapter for the air inlet on the compressor side.
They all have slightly different exhaust housings as well.
The t25 would be the easiest fitting turbo and definitely is better than the original t2.
Old 30-07-2010, 22:50
can i put my t2 cast exhaust elbow on a t25?
i'm after the closest thing to a bolt on swap out! my s12 is my daily so 'll need to have it fitted & working within a weekend
modding my intercooler pipes is no probs just the turbo is the worrying part!
i have a t25 off a rover it boosts & does'nt smoke for defo but it does have shaft play so i doubt how long it would last once fitted if its a more or less direct ish fit?
what about a t25 off a ca18DET?
let me "the clueless" know! :OP
