Old 10-03-2011, 23:15
sjef200sxTurbo's Avatar
Default turbo on fire
finaly got my 84 ca18et running after 1,5 years when it just wouldnt start,
today ive set te ignition timing to 15deg bdp.
and it feels like its retarded too much , even the turbo and manifold get so hot it actually caught fire,
it never seemd to have this problem before when it ran but i remember my buddys old 84 used to have the same problem,
another thing is that on both my s12's the was a resistor solderred between the water temp sensor and ive always found this odd, seemd like they were trying to cheat a sensor.
is this a more common problem ? or could this be the knock sensor?
87 silvia (ca18det)
84 silvia (ca18et oldtimer)
Old 12-03-2011, 11:16
runs pretty good without tortching itself, had too adjust to arounf 17deg bdp.
strange right?
Whats the stock fuel preasure ? cause i got a adjustable regulator.
87 silvia (ca18det)
Old 12-03-2011, 11:26
strange right?
some where between 37 and 43 psi.
Old 14-03-2011, 09:47
thanks il set it in the middle of that, it runs fine now but i had to retard the ignition a couple deg.
87 silvia (ca18det)
