Old 22-10-2012, 21:11
nedge2k nedge2k is offline
Administrator
Default Extreme tramlining
Not sure what the hell is going on here but over road imperfections and white lines my steering is pulled all over the place - if you're not holding tight it can pull the wheel out of your hand!
Track rods are fine, bushes are fine, ball joints are fine, steering rack is secure, wheel bearings are good and nothing funny about the tyres - std s13 wheels/tyres at the mo.
I can only assume the steering rack or pump is knackered? Steering feels quite heavy, heavier than my other s12s and when you wind the lock on round a roundabout, it jerks in and out.
Anyone else ever come across this behaviour?
1985 Mk1 Black Auto
1989 Mk2 Red Auto
1988 Mk2 Blue Manual
1988 Mk2 Blue Manual (Donor)
Old 23-10-2012, 13:58
Only tramlining problem I have is with my Z3!
Is that the steering wheel jerking about on roundabouts?
Any play in the rack? Might need to check and several places along the rack.
Try simple things first, alignment check could cause it to be skitish
Old 23-10-2012, 14:44
Administrator
Sorry, forgot to say, just had laser alignment done after I changed track rod in a hope to cure it! (was happening before I did track rod btw).
Doesn't appear to be any play, wheel moves with wheels and not long had MOT done and nothing found then.
1985 Mk1 Black Auto
1989 Mk2 Red Auto
Old 24-10-2012, 08:02
what profile are the tyres?
Same make on the rear - try swapping them over?
Check torsion rod bushes, neutral caster can effect tramlining aswell I think.
Old 06-12-2012, 01:23
Administrator
So finally got round to swapping the stock S12 wheels off my donor and onto my daily - problem solved. Not entirely sure what it was about the S13 wheels/tyres but but she no longer tries to tug me over every contour in the road!
1985 Mk1 Black Auto
1989 Mk2 Red Auto
Old 26-01-2013, 23:32
Default I get nasty tramlining too
I just thought the car was a bit crap at handling and I have no faith in it, I have 17" wheels on with 205/45 17 bridgestone potenza tyres and it is randomly eratic on the road. I noticed alot of the suspension rubbers are getting a bit worn will this be a factor?
Old 27-01-2013, 11:37
it must be mate, i've poly bushed mine and it handles well.
Old 27-01-2013, 16:44
Default poly bushes
where did you get the poly bush set from?
Old 27-01-2013, 16:46
Default shocks
I also got told to swap the oil in my front shockers for atf but in my eyes atf is thinner and would make the shock softer???
Old 27-01-2013, 17:02
superflex mate, theres a thread on here with part numbers.
