Old 20-06-2013, 23:10
Default Intercooler / piperwork?
gonna be at that point soon, which saab/volvo intercooler fits and how do i go about with pipework?! Still running the ca18et.
Old 09-07-2013, 20:02
-Bump...... no one shed any info on how to go about this? Was thinking about just using exhaust tubing and some hose bends. Cheapo is the idea as you may be able to tell...
Old 09-07-2013, 20:15
are you still on the t2 turbo ?
Old 09-07-2013, 21:07
tim murphy's Avatar
hi bigdave hows yours silvia doing moving forward mine no time on her been welding my van for about two weeks now should have scrap her have owner 6 years . about inter cooler looking on buying one on ebay for 200 sx or 18 et engine cheers
Old 10-07-2013, 11:24
nedge2k nedge2k is offline
Administrator
i've just bought this...
http://www.ebay.co.uk/itm/3004140497...84.m1439.l2649 (saab 9000 cooler)
...which has the same 2" pipe work fittings. i plan to use a combo of new pipes from ebay, some of the existing s13 sidemount currently on mine and some of this to make life easier...
http://www.ebay.co.uk/itm/Black-Sili...item27bbce2497 (flexible silicone hose, rated to 180+ degrees, 13.5 bar)
1985 Mk1 Black Auto
1989 Mk2 Red Auto
1988 Mk2 Blue Manual
1988 Mk2 Blue Manual (Donor)
Old 10-07-2013, 16:02
put a proper bar and plate intercooler in there, with cast end tanks, mines cheap enough and would'nt take much fitting
Old 10-07-2013, 16:15
Im running the T2 still. Will upgrade later on but ok for now. S13eater how much piping/bends etc are with your intercooler? I considered yours previously but was a little unsure
Also Nedge that flexible hose looks like the business but can you cut it to length without risk of leaks?
Old 10-07-2013, 16:17
Administrator
No idea yet but would imagine so. There's some other stuff on fleabay too that looks a bit more conventional but it doesn't give a pressure rating
1985 Mk1 Black Auto
1989 Mk2 Red Auto
Old 10-07-2013, 20:29
theres a company called ash silicone hoses that is cheaper than samco and a lot cheaper, i use them.
Old 11-07-2013, 00:52
Administrator
yep, samco can fuck right off
http://www.ebay.co.uk/itm/180679850121
1985 Mk1 Black Auto
1989 Mk2 Red Auto
