If you email them then they will get them for you.
I've seen them on ebay before as well. |
is this the diff you've got ?
http://cgi.ebay.com/ebaymotors/OBX-H...item2a0b294c41 Was it easy to install ? What about shimming it? And the last Q is I see you've used the standard shafts, were they a straight fit in this LSD?
you need 2xs12 short shafts, (passenger side), then shorten 1 of them by 8mm by grinding the end and deepen the grove on it so that the snap ring fits, then the other shaft, you take the splined end off and fit the flanged end on off of an s13 shaft, then you use the pot joint out of the s13 diff into the s12 diff, which mates up to the flange on the shaft.
http://nissansilvia.co.uk/vbb/showth...highlight=diff
It's designed for an s13 with open diff so the original shafts fit straight in. It's a straight copy of a Quaiffe lsd. I've read that you need to replace the belleville springs in the obx cos they are crap but I've had no problems with mine and I'm running more than 300bhp. I like it as a road use lsd as you really won't notice it's there unless you are giving it the loud pedal. |
They'd be the original shafts
I thought I'd best check before I start thinking of raiding the piggy bank
Only problem is do I replace the other pinion bearings to make sure they dont give up once on the road. This would mean a whole load of hassle according to the Manual. In the meantime I have sent an email to RHDJAPAN.com to enquire on the prices of the bearings
