Old 22-03-2010, 20:19
PureButeS12's Avatar
Default S12 LSD conversion with S14 bits query
sorry to sound like a douchebag but i've found sum1 local who's breaking an S14 & will let the rear diff & drive shafts go for £90
this has been briefly discussed in other threads but can any1 please give me an idiot guide to exaxtly what i have to do to make this work
Old 22-03-2010, 21:22
irish s12's Avatar
Much easier to buy an lsd thats made for a 200sx with open diff.Then it's just a bolt in setup.
Old 22-03-2010, 22:40
Are your sure about this?
You mean LSD for an open diff R200 for 200sx s13 or s14 it's a bolt on on our R200? Never found some who made it (despite of the flange, the specs of axles).
I just want to trust you seems too good to be true.
Old 22-03-2010, 23:16
irish s12's Avatar
Have a look at my build thread,I've got an OBX 200sx lsd and it was bolt in
Old 23-03-2010, 10:32
here?
http://www.nissansilvia.co.uk/vbb/sh...?t=2911&page=7
Old 23-03-2010, 15:30
You're best to get an LSD for an open S13 diff
Old 23-03-2010, 16:34
i thought s13 & s14 diffs were pretty much the same?
Old 23-03-2010, 16:39
Yeah but I think the S14a has a thicker shaft (the splined part that goes in the diff unit)
Old 23-03-2010, 16:45
do you think it'll be wise for me to get a spare s12 diff to try this with, don't wanna pull mine apart & be stuck
Old 23-03-2010, 16:52
Yeah I would. At the end of the day if you buy a diff that is designed to be installed in an S13 case that uses the S13 open type shafts you are likely to be fine
