Old 12-08-2010, 21:47
i can still get them for cheap, tell me the size that is printed on your cylinder and i'll get you a price, i used an s14 one with the rb25 box, steve, did you get my pm about the rear subframe? i wanted to know how many mm you slotted it for the camber conversion.
I will check and get back.
I havent got a PM matey but from memory it was the same again as the bolt hole. As I was only going -30mm and would have only needed 2 degree's ish. If you going more than that I would add some more but be carefull as you would be going off the bottom of the standard bracket, if you see what I mean
